Re: My repowered 1953 Super H
Posted by r4etired on May 04, 2005 at 19:27:31 from (64.12.117.13):
In Reply to: My repowered 1953 Super H posted by r4etirerd on May 04, 2005 at 16:48:09:
I cut down a chev 4speed and mounted it in the torque tube. 2nd gear in the four speed is a 2to 1 reduction, I removed all the excess gears and welded it in second. at3600 rpm in the V6 the transmission input shaft in the tractor is turning 1800, so the ground speed in the H is standard.
Post a Followup
