Re: How to ID an old Farmall tractor??????????
Posted by Sloroll on May 05, 2005 at 13:08:07 from (69.66.43.59):
In Reply to: How to ID an old Farmall tractor?????????? posted by Tx Jim on May 05, 2005 at 11:18:23:
F-12 and F-14 have straight rear axles and the F-20, F-30 and Regulars have a drop rear axle. The regular will have (generaly) open steering gears at the top of the steering pedistal. The F-20's fuel tank if viewd from the back will be somewhat square and an F-30's will be taller than it is wide.
F-12s (Straight rear axle)generally will have the stearing column straight across the top of the hood with a cast stearing wheel while an F-14,s stearing column will angle upward toward the operator. MOst F-14s have a composite steering wheel.
These observations are assuming the tractor hasn't been modified.
Check out Tractor Photos to the left on this page and search each. A picture is worth a lot more than my rambleings.
Post a Followup
