Re: Farmall H with an M W clutch
Posted by Brian A on May 05, 2005 at 19:35:36 from (63.232.132.41):
In Reply to: Re: Farmall H with an M W clutch posted by DWV on May 05, 2005 at 06:17:05:
DWV
I guess my question is can I reinstall the brake drum without pulling pinion cage. I have both seals for it but the drum did not just slide off freely. After I removed the retaining ring I had to use a puller to get it off. I was wondering if there was much of an interference fit on the splines. I don't know if I should try to drive it back on or if I need to pull the pinion cage. My book says that the left bull gear will need to come for that to happen. Should that brake drum slide freely on the splines? Thanks
Post a Followup
