Farmall Tractors Discussion Board
Re: M Carburator
Posted by Bob M on December 11, 1999 at 17:44:02 from (171.219.77.118):
In Reply to: M Carburator posted by David Golden on December 11, 1999 at 11:24:06:
The Red's advice is right on as usual... But you might also try this: Remove the square head pipe plug from the bottom of the carb bowl. Then open the shutoff valve at the sediment bowl and let gas run thru the carb for a few seconds. That'll flush water and junk from the bottom of the bowl without taking it apart.
If that doesn't help, figure on taking the carb apart for cleaning and new gaskets.
Post A Followup
: Re: Re: M Carburator
