Re: super a oil
Posted by Hugh MacKay on May 06, 2005 at 17:13:04 from (209.226.247.13):
In Reply to: super a oil posted by William P on May 06, 2005 at 07:52:24:
William: As Captain said if you change to detergent oil be ready to deal with the dirt you loosen up. I once did this with an engine I knew was dirty. In 4 days I changed the oil or I should say attempted. Removed the plug and nothing came out. Stuck my finger in the drain hole, and it felt like board. I removed the pan to find about 1" of sludge across bottom of pan. I cleaned the pan, changed the filter, put in new 15W-40 detergent oil. That was close to 20 years ago, and as of 4 years ago tractor was still going without a rebuild. The owner didn't use it a lot but when he did he worked it hard.
I personally think detergent oil is the best way to go. I've been using detergent oil now close to 35 years. I used to use 20 in winter and 30 in summer, now I use 15W-40 all the time.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
