Re: Farmall A Carburator
Posted by Dixieland on May 06, 2005 at 20:17:26 from (69.179.199.187):
In Reply to: Farmall A Carburator posted by Duane H. on May 06, 2005 at 18:39:57:
Hi Duane. There should be a round brass tag (button) with the numbers you need on the carb. You will need to clean it up good probably to see the numbers. One set of numbers is the manufactures number and the other is the carb model number. Good luck
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
