Re: Checking RPM's
Posted by Bob M on May 07, 2005 at 11:28:06 from (69.205.121.248):
In Reply to: Re: Checking RPM's posted by Andrew Z on May 07, 2005 at 10:55:52:
Andrew - You"ve got a couple of options:
1 - Get the tach that"s calibrated for a pulse every 1/2 revolution. Wrap the antenna wire around the high voltage wire that runs between the coil and the center of the magneto cap, or...
2 - Get one calibrated for 1 pulse every 2 revolutions - wrap the antenna around any one of the spark plug wires.
Bob
Post a Followup
