Farmall Tractors Discussion Board
Re: Pops out of 1st gear
Posted by big fred on December 11, 1999 at 21:30:57 from (199.238.169.143):
In Reply to: Pops out of 1st gear posted by Otis on December 11, 1999 at 21:12:08:
It's a pretty simple job to take the transmission cover off to check it out. I think it's 12 bolts, you will probably need a new gasket. THere is nothing in your way, it comes straight up and goes in pretty easy. I would suspect either worn gears or bad bearings, in which case you got a big job ahead of you, or lots of wear in the shifter mechanism, maybe a bent shifter fork. If it's a bent fork, you might be able to get it straightened and/or welded (if it's cracked) or start calling salvage yards. When you put the cover back on, just put the shifter in neutral and move the gears by hand so none are engaged and it should slip right in.
Post A Followup
: Re: Re: Pops out of 1st gear
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
