M Transmission Question
Posted by Paul A. on May 09, 2005 at 04:08:58 from (129.9.163.106):
Hi, I am trying to remove the countershaft on my M, to change a damaged 4th gear. Is there an easy way to get the snap ring off the rear of the countershaft? I have removed the brake shaft (so I can see the snap ring), but the snap ring pliers I have will hardly budge it. Is there a heavier duty pliers that work better for it? Thanks, Paul.
Post a Followup
