Re: What's wrong with my H?
Posted by Jake1944 on May 09, 2005 at 05:28:51 from (67.136.148.160):
In Reply to: What's wrong with my H? posted by pdonoh on May 08, 2005 at 16:26:03:
Pull the needle at the side bottom on the left of the carb. High speed adjustment needle. it should pour fuel out steadly. This will help clean out the bowl and tell you if the needle and seat is plugged. If it is pours out it is not plugged. If it does not trash has stopped up your seat and not letting enough fuel in to run a high rpm but enough to idle. Hope this helps.
Post a Followup
