Re: Sticks in Gear
Posted by captaink on May 09, 2005 at 13:34:59 from (66.115.214.56):
In Reply to: Sticks in Gear posted by wolfmantractor on May 07, 2005 at 16:59:12:
Adjust it like Hugh says. If that doesn’t fix it, then it could be the clutch. The 460 and 560 originally had a full circle fiber clutch disk. Many were switched out at one time or another to the Dyna-life button clutch which has a hard metallic buttons instead of the fiber. These were notorious for chewing up flywheels and pressure plates and when they did, a curved edge forms on the inside and outside diameter were noted to cause dragging on the clutch disk making it almost impossible to shift gears standing still unless you pulled the TA.
Post a Followup
