Re: How to Identify
Posted by K.B.-826 on May 09, 2005 at 20:21:00 from (66.188.217.177):
In Reply to: How to Identify posted by Earthquake on May 09, 2005 at 19:47:14:
Usually, there's a model/serial number tag on the clutch housing. If not, post back with as good of a discription as you can. Make sure to include the number of speeds in the transmission, how many cylinders the engine has and if it is a gas or a diesel, and any numbers you can find on the castings. Also try to determine if it is a row-crop, standard, or utility tractor. It would really be easy if you could post a picture. Look around in the "Tractor Photos" section and see if you can find somthing close.
Post a Followup
