Re: super C gas in oil?
Posted by captaink on May 10, 2005 at 08:12:12 from (66.115.214.56):
In Reply to: super C gas in oil? posted by skippy on May 09, 2005 at 16:20:25:
Is the carburetor dripping when the motor is shut off? If not, then I highly doubt that it is a carburetor problem unless the mixture screws are really out of adjustment. The reason is that as has been previously said, it has an updraft carburetor which would generally prevent gas as a liquid getting into the cylinders. Now, if the engine is running too rich (lots of black smoke from the exhaust), or has very poor compression (which is indicated by the smokey mist coming out of the breather) all the fuel may not be getting burned up and pushed by the rings into the crankcase. Usually if an engine is run long enough and warmed up good the gas will evaporate out and you won’t notice it in the oil, but if the engine is run short periods of time, it will tend to collect in the oil. Others are correct about changing the oil, since gasoline (especially ethanol blends) has a tendency to remove oil from the places it needs to be. Not good. After you change the oil run that engine for an hour or so and get it warmed up, check to see if you still are getting gas in the oil. If not, then it’s pretty likely coming past the rings either due to starting and stopping the engine before it is warmed up, poor compression, or too rich a setting on the mixture screws.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
