48 Cub Low Boy
Posted by Robert Smith on May 10, 2005 at 18:07:04 from (70.105.88.15):
I got a 48 Cub I use to mow with and have a problem that I could use some help with.
The throttle level just froze up, was working fine and I backed the lever off and noticed it seemed a little stiff then when I opened it back up it has stuck and will not move at all !
As luck would have it, It is stuck wide open so I could finish mowing with it but now want to find out whats going on !
I've never owned a Farmall before so I know little about them so any help would be great befor I go tearing into it!
Any Ideas where I should start?
Dose this lever rod run to the governor?
The governor seem's to be working as the load vary's on the motor?
Any help would be great !
The grass is growing so I need to get her going!
Post a Followup
