Re: power beyond on an 856
Posted by K.B.-826 on May 11, 2005 at 21:09:12 from (68.115.97.206):
In Reply to: Re: power beyond on an 856 posted by Allan in NE on May 11, 2005 at 16:10:47:
Allan, power beyond is hydraulic supply after the factory remotes. There are two types of hydraulic vavles used on the 706-1566, open sided and closed sided. 06"s with two valves usually had two open sided with a plate over the left side of the outside valve. To get power beyond out of these, you simply replaced that plate with a power beyond plate, which was basically just a plate with two threaded holes to screw fittings into. 26, 56, and 66"s usually had a open sided valve on the inside and a closed sided valve on the outside. On these, you have to replace the closed sided valve with a open sided valve and then add the power beyond plate.
Post a Followup
