Farmall 560 tractor
Posted by eric stephen on May 12, 2005 at 14:05:26 from (216.135.46.218):
Ihave a farmall 560 tractor for sale, it is in excellent condition. It has been overhauled, it has new pistons, rings, bearings, and a valve job. It has four new tires, they are Firestones, and the rear rims are new. the sheet metal is straight and it has a new paint job. It also has a new generator, battery, muffler, steering wheel, and seat. It has a narrow front, with a two point fast hitch. Eric Stephen 1.812.431.
5407
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
