Farmall Tractors Discussion Board
Re: Farmall H sparkplugs
Posted by Phil Auten on December 12, 1999 at 10:37:50 from (206.175.72.226):
In Reply to: Farmall H sparkplugs posted by Ron Linsmeier on December 12, 1999 at 06:09:08:
Ron,
The Autolite 3116 cross references to a Champion D18. They will work fine. If they foul out quickly, try the numbers The Red gave you, they are for a hotter plug. You'll probably need to go to a hotter plug unless you will be working the tractor pretty hard as today's unleaded gas is crappy compared to the gas from the 40's and 50's.
Phil
Post A Followup
: Re: Re: Farmall H sparkplugs
