Re: farmall a oil in water
Posted by El Toro on May 13, 2005 at 03:06:32 from (205.188.117.138):
In Reply to: farmall a oil in water posted by farmall ron on May 12, 2005 at 19:46:56:
You may have a sleeve leaking around the seal at the bottom of the sleeve. See if you notice bubbles in the radiator when the engine is running. A good indication of a head gasket leaking or blown. I would drop the oil pan and see if any coolant is leaking from around the bottom of the sleeves when the tractor is just sitting. Set a dry tub under the engine and let it sit all night. Any leakage means you will have to pull the pistons and sleeves to replace those leaking sleeves seals. Hal
Post a Followup
