Re: farmall a oil in water
Posted by supergrumpy on May 13, 2005 at 11:33:28 from (24.213.235.108):
In Reply to: farmall a oil in water posted by farmall ron on May 12, 2005 at 19:46:56:
just went thru this with a 400
let tractor sit a few days or as long as you can, drain some oil out of crankcase and see what color fluid comes out before the oil, clear is water, colored is anti-freeze
ours was clear, rain was running down outside of exhaust stack and into exhaust leak where stack pipe screws into the exhaust manifold
Post a Followup
