Re: m rebuild ?
Posted by captaink on May 13, 2005 at 19:49:16 from (64.33.250.37):
In Reply to: m rebuild ? posted by gtg155 on May 13, 2005 at 12:05:23:
If by chance you can get a hold of an inside micrometer, get it and measure the inside of the sleeves for wear and taper (a sleeve wears more at the top). If it is minimal as you say I would just clean off the ring ridge hone and put in new rings. I really don’t think the oversize rings are worth it.
Post a Followup
