Re: SM on LP won't start
Posted by BIG JOHN on May 14, 2005 at 18:36:59 from (152.163.101.13):
In Reply to: SM on LP won't start posted by Mark L. on May 13, 2005 at 19:42:56:
Chances are that you are not getting any LP in the tank on the tractor. Probably the pressure in both tanks is about the same. Since your tractor is still on the trailer take it to a LP dealer and he can pump liquid propane into your tank. The small tank that you are trying to use only lets out vapor. If you can connect your small tank directlly to your vapor line that will also work until you can get some liquid pumped into your tank.
GOOD LUCK
Post a Followup
