Re: 4568
Posted by Doc Holiday on May 14, 2005 at 20:04:50 from (216.16.56.227):
In Reply to: 4568 posted by The F-20 Man on May 14, 2005 at 15:24:37:
Parts are still available for the DVT-800 engine. But you better hold up a bank on your way to the dealer...lol Last set of sleeves and pistons I put in one ran over $900.00 a hole. That engine weighs close to 6000lbs, so you better have the right equipment to handle it. The engine itself was not all bad, very heavily built and extreemely well balanced. But, in farm tractors the chassis lacked proper radiator capacity and the engine air intake systems were a joke. So many of those engines expired needlessly when a air filter plugged up. Once the air filter plugs the motor will pull the oil up out of the crankcase and burn it....once the crankcase is dry...BANG...and out goes a rod through the side. Best thing to do is cut a hole in the hood and stick a 6" (at minimum) pipe out with a precleaner up on top. Most of those tractors are repowered with either a Cummins or Cat engine...the frame has to be extended to fit the 6 cylinder engine in...but you end up with a cheap, inexpensive and easy to service tractor when you are done. Transmission is Spicer, drop box is Steiger & the drive units are standard IH. So .... parts are available anywhere quite reasonably. Doc
- Re: 4568 scot_c 18:09:30 05/15/05
(2)
- Re: 4568 Doc Holiday 19:27:13 05/15/05
(1)
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
