Re: SM on LP won't start
Posted by GWT on May 15, 2005 at 12:45:14 from (198.178.8.81):
In Reply to: SM on LP won't start posted by Mark L. on May 13, 2005 at 19:42:56:
Mark, It"ll take a while. But it will be enough to get the tractor moving. I used an old fork lift tank and could get the liquid out fine. It has to do with the position of the intake inside the tank. Your BBQ tank would work if you held it upside down.
Just get that guage to register, (it might take a couple times with that small tank, (gas can)). What I"ve done is holler at the LP guy when he comes to the next house down, and he"ll fill it.
Since you just got it, you might want to check those valves for leaks. You know, bubble juice.
GT
Post a Followup
