Re: rebuilt H startup, no oil to rocker arms!!!
Posted by Theman on May 16, 2005 at 11:35:33 from (65.248.77.5):
In Reply to: rebuilt H startup, no oil to rocker arms!!! help posted by arod on May 16, 2005 at 11:04:28:
Pull the rocker assembly and check the oil hole that supplies the head from the center cam bearing. I recommend using a piece of unfluxed 1/8" brazing rod. Use it as a depth gage to see if the passage is clear. If the rod extends past where the head gasket would be, the next source of blockage is the cam bearing. If it wasn't properly installed, oil won't make it to the head. To verify the bearing is in the correct position, round the end of the brass rod leaving it blunt with no sharp edge. Turn the engine over slowly by hand (remove the spark plugs) and see if the rod dips in the slot on the camshaft or if you feel it rubbing against the bearing surface. Be sure to turn the engine over twice so the cam makes a full rotation. If nothing happens, the cam bearing needs to be replaced.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
