Re: Alternator question, Bob M?
Posted by Bob M on May 17, 2005 at 04:21:16 from (151.190.254.106):
In Reply to: Alternator question, Bob M? posted by Tractor Tom on May 16, 2005 at 21:38:49:
Tom - I'm not familiar with the Mitsu alterator. However you may be able to figure out the aux terminal connections using an ohmmeter.
Measure the resistance from each terminal to the alternator case. One terminal should show very high resistance (tens of thousands ohms). This will be the "voltage sense" terminal and gets connected directly to the alternator output stud.
The other will show low resistance (only a few ohms). It should be connected to the switched side of the ignition switch.
However this is just an educated guess - use at your own risk!!
Post a Followup
