Re: Resleeving a 464 gas motor
Posted by El Toro on May 17, 2005 at 05:51:53 from (205.188.117.138):
In Reply to: Resleeving a 464 gas motor posted by Eddie in KY on May 16, 2005 at 22:56:17:
To remove those sleeves you need a sleeve puller.
You may be able to rent one. You should buy a shop manual that covers that tractor too. This will give you all the tolerances and torque specs.
If you're going to pull the engine this would be a good time to have the engine cooked and new cam bearings installed. You could also have the old sleeves pulled too. Then you could replace the clutch if needed. Hal
Post a Followup
