Re: One legged 'A'
Posted by lee on May 17, 2005 at 17:19:54 from (68.225.113.254):
In Reply to: One legged 'A' posted by Dixieland on May 16, 2005 at 19:03:53:
jack one side, block it up, jack the other, block that side. Wedges both sides in front can work but must be absolutely secure if you plan to single point jack the rear at center, not recommended by me at least. If a wedge slips or breaks up she'ds going over. Why go the wedge route if you have the axle housings or draw bar in place to block both sides at the rear? Only time I ever wedged the front was when I removed axle drive shaft/bull drive housings. Get some serious wood blocks to block your tractor. Rail ties or big treated wood works good. Don't use cheap jack stands or balsa wood blocks.....
Post a Followup
