Re: Oh my gosh! No filter in my H!
Posted by captaink on May 18, 2005 at 07:37:10 from (66.115.214.56):
In Reply to: Oh my gosh! No filter in my H! posted by Gary The Rookie Farmer on May 17, 2005 at 15:05:03:
You asked “how much damage might have been done” in your post. A lot MIGHT have been done if the oil in the engine had a lot of crud in it, but read on.
As others have said, if you still have good oil pressure and don’t hear any knocking from the engine, just change the oil and put in a new filter. The cleaner the oil the better off the engine will be.
Now what damage might have been done is dirt or carbon pieces may have passed through the bearings on the crankshaft and put grooves in them. Normally, the bearing is soft enough to absorb the foreign material and the crankshaft will remain unharmed. However if the piece is large enough, it will damage the crank. The impurities could also have gone through the camshaft bearings and done similar damage as on the crankshaft bearings. Worst case is that something would have lodged between the piston and sleeve and scored them. There may also have been damage done to the oil pump gears if big enough pieces of crud went through the oil pump.
I don’t want to alarm you but this is what MIGHT have happened, not what did happen.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
