Re: IH 330 U
Posted by captaink on May 18, 2005 at 14:11:05 from (66.115.214.56):
In Reply to: IH 330 U posted by Brad Sprague on May 18, 2005 at 12:48:30:
If immediately after it died the battery had enough power to turn the engine over even only once, chances are that the battery had enough power left to run the engine. Connections on the battery are another issue as a poor connection might act exactly as you describe. I’d suggest checking the battery cable connections and ends. If you see corrosion that you can’t get cleaned off, it would be best if you would replace it. You may also have a bad connection between the battery and the coil causing the engine to cut out.
Post a Followup
