Re: E-85 vs Distillate
Posted by LenNH on March 07, 2009 at 14:21:07 from (71.235.191.159):
In Reply to: E-85 vs Distillate posted by F-Dean on March 05, 2009 at 19:05:26:
Don't know much about E-85, but it appears from what people are saying here that it works with high compressions. I grew up with several "kerosene" or K-D tractors (10-20, "Regular," F-20, H) and nobody I knew was using kerosene or distillate anymore after maybe 1935. It's just too much trouble (start on gas, warm up to HOT or it won't run right, keep it HOT, shut off fuel to stop, etc.). Gasoline in those low-compression engines (a little over 4 to 1, probably) works just fine, but it is certainly not going to bring the power you'd get with compression around 6 to 1, which is what I think it would have been once you could buy an engine specifically for gas (like with F-12, F-14, H and M, etc.).
