Re: How difficult in frame rebuild?
Posted by Coytee on April 06, 2009 at 08:57:38 from (76.123.227.230):
In Reply to: How difficult in frame rebuild? posted by Coytee on April 05, 2009 at 11:26:45:
ih560 said: Yes, the item you have circled is the oil cooler, and your engine is the D360 instead of the D358. It is fairly common for those oil coolers to fail and leak coolant into the oil. The good news is, the D360 is less likely to cavitate than the D358, bur it is still possible just not as likely. I would start with the oil cooler, and work from there. It is fairly easy to remove and you should be able to pressure test it without too much work.
To pressure test it, would I need to remove it and take it to a radiator type repair shop?? How might I do that myself?
If in fact, this cooler is the culpret, would I simply replace it or is that something a radiator type shop can weld/solder/recore like an auto radiator??
I'm more optimistic with the comment about D360 vs D358!! but I will still not get my hopes up until problem is verified!!
Thanks for your guidance thus far
