Re: resurfacing valve lifers
Posted by El Toro on May 19, 2005 at 05:20:38 from (152.163.101.13):
In Reply to: Re: resurfacing valve lifers posted by jnewark on May 19, 2005 at 04:59:39:
I thought water was the culprit. I think you should try and reface one of those lifters since
your cam lobe should give you enough valve lift.
Just remove enough to make it smoothe. Hal
Post a Followup
