Re: Allan in NE, Hugh, and other Cyclo owners
Posted by captaink on May 19, 2005 at 09:13:54 from (66.115.214.56):
In Reply to: Allan in NE, Hugh, and other Cyclo owners posted by P Backus on May 19, 2005 at 07:05:22:
Paul,
I can’t answer most of your questions, but I believe the bottom line is that the unit you have from the planter will work just like it did on the planter even though your drill has double acting cylinders. If you install it on the lift side of the cylinders, the markers will lift when you lift the drill. There may be some “feedback” from the oil returning when you let the drill down, keeping the marker up until the pressure drops to 0 and then allow the marker to drop.
My thoughts…
Post a Followup
