Re: Anyone seen this setup on SM
Posted by Nat on May 19, 2005 at 14:31:35 from (64.80.110.40):
In Reply to: Anyone seen this setup on SM posted by Ty1 on May 19, 2005 at 09:39:34:
Should be a fairly simple mystery to solve. Go in under the tractor's belly. I believe there's an access panel so you can get at the drive shaft for the belly pump. See if there's a drive shaft installed. No drive shaft? Then Aces is right. When the live pump was installed, it was plumbed so the lift-all's control valve could be used to run the hydraulics. You can safely connect the IN side of the triple-spool valve to the pressure side of the pump, and eliminate the belly reservoir. It only holds 3 quarts of oil or something like that anyway. Drive shaft? Then captaink is right. The pumps are working in tandem, though I don't really know what purpose that would serve.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
