Re: 504D and 606 front end
Posted by Hugh MacKay on May 19, 2005 at 17:37:20 from (209.226.106.136):
In Reply to: 504D and 606 front end posted by JR in TX on May 19, 2005 at 15:17:52:
JR: If the 504 has a single front wheel then it has to be a Farmall, whereas the 606 and 2606 were only ever built as Utilities thus the front ends are completely different. The Farmall 504 wide front was completely different from most other Farmalls as well. I think only the Farmall 340 has the same wide front. You may be able to buy a new aftermarket wide front to fit.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
