Re: Removal of M crankshaft
Posted by FarmerSid on May 20, 2005 at 03:55:15 from (216.209.110.148):
In Reply to: Re: Removal of M crankshaft posted by El Toro on May 20, 2005 at 02:39:55:
You need to pull the engine because the flywheel and clutch assembly which is bolted to the crank. On the front of the engine, the big cast timing cover needs to come off. Before the timing cover can come off, the crank pulley has to come off. There is quite a few parts that need to come off in order to get the crank out. Make sure you make note of where and what orientation each main bearing cap and rod came off.
Post a Followup
