Re: Allan in NE, Hugh, and other Cyclo owners
Posted by ohjeffoh on May 20, 2005 at 05:07:39 from (198.30.81.2):
In Reply to: Allan in NE, Hugh, and other Cyclo owners posted by P Backus on May 19, 2005 at 07:05:22:
all you have to do is run a hyd line from the unused auxillary, (usually the bottom) and T it off to pressurize the down side of the cylinders. I"ve never done this but in theory it will work. I do run a 400 and when i drop it i put it in float. to run a setup like this you would have to position the lever in the lower position until the two way cylinder is retracted before going to float
Post a Followup
