Re: Farmall A clutch
Posted by captaink on May 20, 2005 at 06:56:23 from (66.115.214.56):
In Reply to: Farmall A clutch posted by wijake on May 19, 2005 at 16:29:32:
The fingers can be worn both on the surface that contacts the throw-out bearing and where the pivot pins go through. The fingers should have a nice curve to them where they contact the bearing. They will wear flat with use to the point that the curve actually will wear completely away. If the metal on the curve is comparative to the thickness of the rest of the finger, you should be all right. If it is getting thin, I’d replace at least the fingers. If the pivot holes are worn oblong, then you should replace them also, probably with a rebuilt pressure plate assembly.
Post a Followup
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
