Re: 48 Cub won't fire
Posted by MagMan on May 20, 2005 at 17:48:45 from (64.12.117.13):
In Reply to: 48 Cub won't fire posted by WOD on May 20, 2005 at 12:26:20:
If thats a Magneto converted to an external coil then it will not have a dust cover there will be a plate with three screws that hold it on over the points and condenser. Also in my opionion I would replace the condenser if the points dont look to bad but Condensers will go bad just sitting it happens on all small engines as well or older ones that is the newer are electronic. But anyhooo if its a mag and you took the rotor off did you get it timed corectly when you put it back???
MagMan
Post a Followup
Today's Featured Article - History of the Field Marshall Tractor - by Anthony West. Any restorer who has some knowledge of turn of the century farm machinery, will recognize the name Lanz Bulldog!! This machine was to say the least unusual in its appearance. The huge flywheel and coffee percolator shaped exhaust. Along with square body lines and cylinder head protruding forward of the front axle. Would become the visual differentiation that people would quote to separate the Lanz from other period machines. The Marshall company based at the Briannia Works in Gainsborough ... [Read Article]
