Re: Super A clunking
Posted by ddg on May 21, 2005 at 03:34:16 from (64.12.117.13):
In Reply to: Super A clunking posted by sensato on May 20, 2005 at 20:37:13:
If you have wheel weights, make sure they're bolted on tight, mine sounds like that if the weights are loose.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
