Re: Super A clunking
Posted by Haas on May 21, 2005 at 14:33:33 from (12.65.48.197):
In Reply to: Super A clunking posted by sensato on May 20, 2005 at 20:37:13:
My guess is that the bolts that hold the rim (4 of them) to the hub are loose. Also could be the weights are loose on the hub. When the rim bolts are loose, it will make a "popping/cracking" sound. Your lack of brakes probably means the differential seal is leaking oil onto the brake drum. The final drive must be removed from the transmission housing to fix it.
Post a Followup
