Re: Altenator question Farmall H thanks Bob M
Posted by Bob M on May 21, 2005 at 18:51:32 from (69.205.121.248):
In Reply to: Re: Altenator question Farmall H thanks Bob M posted by MagMan on May 21, 2005 at 18:08:27:
OK Jon - the other end of that lamp pigtail needs to go to a SWITCHED 12 volt source (one that goes off when you shut down). Could use a simple toggle switch here, but you gotta remember to shut off the switch when you shut down the tractor.
Another option is to use a DPDT switch to combine the alterator control with the mag kill switch function (punch below for a diagram).
Or you can install a normally open oil pressure switch (the switch contacts CLOSE on sensing oil pressure). Use that to switch the voltage to to the warning light. ...Bob M
Post a Followup
