Re: starting a H after ten years of sitting
Posted by old on May 22, 2005 at 08:07:05 from (207.69.136.198):
In Reply to: starting a H after ten years of sitting posted by Scott Sherrick on May 22, 2005 at 07:57:57:
If it where me I'd fill all the cylinders with tranny fluid before I even tried to turn it over, let it sit a day or 2 then and only then would I try to turn it over. The tranny fluid will help loosen the rings if they are stuck and also keep if from haveing a dry start up. I'd also change the engine oil before trying to do a start up because there will probably be water in the oil.
Post a Followup
