Re: starting a H after ten years of sitting
Posted by old on May 22, 2005 at 10:37:45 from (207.69.138.201):
In Reply to: Re: starting a H after ten years of sitting posted by pete ellis on May 22, 2005 at 08:59:41:
The reason I fill cylinders on stuck and unstuck engines that have sat that long it so the rings aren't dry and also to remove/coat the cylinders since they will have some rust on them no mater what. Your a lot less likely to have problems with and engine if that is done then if you don't do that. Every tractor I get that has sat I will do that just to make sure it gets the upper cylinders lubed before I ever start it.
Post a Followup
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
