Re: BN mag timing problem
Posted by RobinPA on May 22, 2005 at 15:14:01 from (66.153.34.98):
In Reply to: Re: BN mag timing problem posted by MagMan on May 22, 2005 at 13:45:18:
Magman- I found the old drive and matched up the new one I think pretty well. The gear running off the cam gear has two marks on it. One mark is a single dot (.) and a couple teeth away there is a dash (-) mark. The dot is marked on a tooth and the dash is marked between teeth. Which one do I use? I read before about two dots, which the old drive has, but the idle gear on the tractor only has the one dot and a dash mark. Thank you.
Post a Followup
