Re: M tire size
Posted by Leroy on May 22, 2005 at 16:53:07 from (216.255.39.168):
In Reply to: M tire size posted by egon on May 22, 2005 at 14:10:35:
12.4 was the old size 11 and was the standard on earlier M's the same as it was standard on all John Deere A tractors but like most of them as well as the Farmall M were changed to one size oversize by going to 12-13.6 for more traction. The rims should be the corect ones for the 11-12.4 tires. You will just loose a bit of speed and traction but you will gain drawbar pulling power
Post a Followup
