Re: Bent Ram
Posted by scotty on May 23, 2005 at 05:39:16 from (199.231.49.128):
In Reply to: Bent Ram posted by Mike in Ontario on May 23, 2005 at 05:20:57:
Mike,
Hope things are going well for you up on the farm! As far as the ram goes, you need to take it apart and find a hydraulic press and some v-blocks to straighten that ram out. I have seen my farmer neighbor use his log splitter and have it work, but very tricky and not much controll such as a hand operated hyd press. Do you have a local machine shop, I would think that is your best bet.
scotty
Post a Followup
