Re: 1066 REMOTE SPEED ADJUSTMENT
Posted by the tractor vet on May 23, 2005 at 12:49:21 from (4.124.92.58):
In Reply to: 1066 REMOTE SPEED ADJUSTMENT posted by CHUCK3 on May 23, 2005 at 12:27:21:
It is either up or down on them as they are and open center system , now on the late 86 seires they are a PFC system and you can select on them . If things are getting slow on the 1066 then have it flow rated and see if the pump is getting tired . They do make bigger pumps but the filter system is the hold back on the bigger pump , now there is was a double filter add on from and after market co. awhile back but i have never installed one or does any of my old customers have one on any of there tractors. So i can not say that they work and are good or not and i will not say one way or other.
Post a Followup
