Re: B Starter
Posted by captaink on May 23, 2005 at 19:31:48 from (64.33.250.37):
In Reply to: Re: B Starter posted by GKTX on May 20, 2005 at 20:10:41:
By dong this test you verified that you do not have a short to ground, but there is still a chance that the windings have lost enough insulation to cause this. I believe that Don V was referring to the windings that are on the outside case of the starter not on the armature. These need to have continuity, and not be shorted to ground (the case) also.
I suggest a good shop that works on starters to get it tested and find out exactly what the problem is with your starter.
Post a Followup
