Farmall Tractors Discussion Board
Re: Farmall H Wide Front - Cost Difficulty
Posted by Farmer Bob on December 13, 1999 at 11:00:54 from (207.227.187.174):
In Reply to: Farmall H Wide Front - Cost Difficulty posted by Jim on December 13, 1999 at 05:46:51:
Jim, If you go with a Schwartz WF you will have the four bolts that hold the frame of the WF onto the front end of the tractor, then the bolts that hold the steering mechanism onto the bottom of the lower boltster. On my M I also had to drill two 5/8" holes in each side of the bottom of the frame rails to bolt up the rear stabilizer frame of the front end. Drilling these holes from the bottom was the most difficult part of installation. FB
Post A Followup
: Re: Re: Farmall H Wide Front - Cost Difficulty
